Quantum QL50
Deenniiss
Can anyone tell me if they have used this reel and how it performed. This one came available for 25 dollors . Is that a good buy? <br />Im new to bass fishing and was told a baitcaster reel was the way to go.<br />Thank you for your input.
NOSLEEP
Re: Quantum QL50
Hello Dennis<br />I have not used the real you mentioned<br />however I do prefer the levelwind (baitcaster)<br />for all my fishing including trolling, jigging,<br />casting,even ice fishing.The level wind allows<br />the line to come off the real with out twisting<br />a spinning real will twist the line. Every time you hear the drag click when fighting a fish ie:<br />he is taking line and you are reeling in.The line<br />twists once for every turn of the handle. This can<br />cause problems with your line after a hard days<br />fishing.However It does take some practice to get the hang of casting with a baitcaster. Some helpful rules when using a baitcaster:<br /> Always remember to reset clutch when changing<br />lures. most lures have different weights and if you don't set clutch each and every time you change lures you will spend all your time removing bird nests from your line after your cast. Start by practicing with a small weight and casting in a Field or on the water.<br />to set clutch drag.click bail button and let weight fall to the ground. set clutch so drum stops spinning exactly when weight hits the ground. As you get better at casting you can let tension off to improve the distance you get.<br />If you use really light line and very small jigs or lures you will still want to use your spinning real, as level winds do not cast as well with very small line and lures .
