Re: Puget Sound 16 S/S
Hey, this is my first post! Just got a '74 16 S/S with a '77 Merc 70. I downsized from a Blue Fin Sportsman 1900 w/85 Force. Hope the S/S will still pull my daughter on skiis. From what I can tell, it's about 365# lighter, so hopefully the performance should be about the same.
Boat has a few issues, but is fundamentally sound. Transom seem to be good, and hull has no significant dings. I may have to replace the floor...though I think that's been done once already. The aluminum strips one either side are still there on mine. One question I have is whether there are aluminum "floor joists" under there...and if so, do they run side to side or lengthwise? Of course, once I lift the carpet, I gues I'll find out...just brought it home today.
Previous owners had removed the original "dashboards", to install a radio on port side and to cover non-functional instrument holes at the helm. The speedo is still around, just not installed, but I'm thinking of leaving it off. GPS is a lot more accurate, and I think I can seal up the hole for the speed pickup easily enough. Also tried to make a bass boat out of it, by making a plywood cover over the open bow and replacing the sliding doors into the fuel/battery storage area with a top-hinged door that swings up to make a flat platform level with the cockpit top. Fortunately they did all this without screwing up the interior too much, and all that's going. The brackets for the original sliders seem to still be there.
The zamak fittings on the bow rail are pretty crappy, so I think I may make the whole rail go away. If I replaced them with stainless I'd significantly increase my investment in this boat. Likewise the several dozen rusty snaps for a cover along the top of the gunwhales.
One last question...the pointed end for one of the rub strips low on the sides is missing. Any ideas on where to find a replacement?
