proper use of vhf?
ms5712
where should i go to get proper use/lingo for vhf radio? i got the uniden atlantis and im not to sure how to make contact to see if she is up and running?
speed29668
Re: proper use of vhf?
Just announce your vessel or first name, that you are calling for a radio check, and the station you are calling. <br /><br />Such as "This is MS calling SeaTow (or any known marina, etc) for a radio check on channel 16" and then thank who ever did so. <br /><br />SeaTow, if they are in your area, usually doesn't mind giving radio checks, they appreciate the mention of their name on the radio. Just read the owner's manual and educate yourself on the proper channels and their uses. You are only allowed to operate on a handful of them.
Spidybot
FYI: In Europe you need a license (issued after taking part in a course) to operate a VHF.<br /><br />Helps a lot in radio disciplines and especially when in an emergency.
Capt. Bob
Chapmans (the "Boater's Bible,") Piloting, Seamanship & Small Boat Handling. If you have never seen one, go to a marine store and look through it. It is "necessary", as far as I am concerned for safe and proficient boating for everyone. All safety and proficiency classes by the Power Squadron and Coast Guard Aux. are designed around this book.<br /><br />Check e-bay for great prices on used copies. :)
Luna Sea
In Massachusetts though, it is no longer proper boating etiquette to use channel 16 for radio checks. Use channel 9! Channel 16 is for emergencies only. Most of the new radios can be set to scan 16 and 9. Happy boating! :p
Stanp
I agree Chapmans is a must for folks to learn from. The person from Mass is right, channel 9 is the proper channel for radio check. If you use channel 16 the coast guard will explain this to you in not so pleasant terms, here in New Jersey.
speed29668
Channnel 16 is designated as calling/distress and all radios are legally required to monitor 16 when not engaged in other uses. Towing services monitor this as well as the Coast Guard. Radio checks on 16 are fine. The Coast Guard does not mind this as long as it stays short-winded. In fact, give the Coast Guard a call when in your normal boating area to be sure you are able to reach them when in an emergency. Most boaters don't even monitor channel 9 and there might not even be anyone on that channel when calling for a check.
Ross J
Can't put enough pressure behind comments already made.<br />In NZ there's enough idiots using boats without appropriate radio lisences to make it sometimes difficult on the weekends especially. Not knowing how to, or what to call is no excuse as there's plenty of courses available locally to sit radio exams.<br />I know it sounds like a lecture but with a ticket on the water those who don't get it right take up a lot of time on the radio.<br />Ross
Luna Sea
Read No. 7 in the following link....<br /><br /> http://www.sacdelta.com/safety/radio.html <br /><br />I believe this explains why NOT to use channel 16 for radio checks. There's a chart that shows what channel 9 is used for also.<br /><br />Happy (and safe) Boating! :D
speed29668
I really like the part that says radio checks are unnecessary. Maybe checking the bilge pumps and other safety items are unnecessary also. 16 is desginated as a calling and emergency channel. If you are calling a specific vessel or station, even for a check, it is perfectly legal.
