clay mills
- Sep 2, 2002
- 9
a buddy of mine borrowed his dad's '59 model Evinrude 10hp. is a 50 to 1 mixture ok? also the engine doesn't run well at wide open. after a few seconds it surges as if you were cranking the throttle from idle back to wide open, over and over. we replaced the fuel line and primer bulb, observed no kinks in the line and even tried it with the gas tank cap removed. milking the bulb seemed to help a little only at idle or half speed.
