Prop Madness...
Jersey13
I know....this topic has been beaten to death but i'm just trying to figure it out once and for all. I'm starting to get the understanding that the best way to correctly prop your boat is to get a baseline on a certain prop and then change the pitch to increase or decrease rpm's to get the motor into optimum operating rpm range of your motor, in your condition. If you have several props with several pitches to try and live on the water, this seems to be a pretty easy task. Unfortunatly, i don't. I'm also figuring that things like rake, cupping, diameter and material (ss, alum) also play a big part in selecting the correct prop, for whatever YOU'RE going to use your boat for. Understood. I called the manufacturer of my boat and asked what was the original prop back in '86 that was sold with my setup and he said 13 3/4 x 21. Fine. Figure that would be a good place to start. The only problem is, the props i'm looking at either come in a 14 x 19 or a 14 1/4 x 21. Which is closer to the stock prop size? Does diameter have a big effect and should you change pitch or rake or whatever if you change diameter? Any info on this would be appreciated and i'm sorry if this post about props is driving people nuts, but, join the crew
<br /><br />- Jersey
JB
Re: Prop Madness...
Yo, Jersey. Since there are no perfect answers to prop questions, they will be asked forever. For what it's worth: SS props have thinner blades, hence less drag. Smaller diameters have less drag but more slip.<br /><br />In your case, I think the 14X21 is closer to the original than is the 14X19. The larger diameter will have slightly more drag but also a bit less slip so it should perform about as the original, assuming both are aluminum. If the new one is SS expect slightly better performance.<br /><br />Bon Voyage<br />JB
Jersey13
Re: Prop Madness...
Thanks J.B. I ordered the 14 1/4 x 21. I should be getting it tomm and trying it out this weekend.<br />- Jersey
