I bought this motor last week and tried to adjust the carb at home. It started at first pull and everything seemed fine except little difficult to find right carb setting at highest speed.
During the high speed setting, the prop hit gabage can by accident. After that, the prop did not or barely spin even at high throttle even the motor was running strong.
So took out the motor from the gabage can and see what happened. The prop spun freely by finger.
I took the prop out and saw the prop inside was broken.
According to the parts diagram from the attached picture, #22 Clutch Hub and #18 Drive Pin (Shear Pin) are cracked and broken.
However, could not take the clutch hub off from the prop. It seems like strongly glued to the prop and so can't be removed.
Is it possible to remove the hub without damage to prop? or do I have to find whole prop with clutch and hub installed? Anyone has experienced with that replacement or anyone can help?
Any advise welcome.
Many THANKS!!
Any advise welcome.
Many THANKS!!
