My 1989 150XP has low WOT rpm-- should be 5-6K, but reads 4K on the tach. I borrowed a timing light/tach to check the tach, which could be off-- but need to get to the water to look at this. However, the prop on this motor is 14 X 24-- which seems highly overpitched and is probably contributing to the low rpm-- i am planning to change. My dumb question: if the tach is ok, and I am looking for additional reasons for the RPM to be low (other than the prop), can i just put the boat in the lake, take it out of gear and rev to WOT briefly to see what the rpm gets up to? Should it get close to 5600 or so w/o a load if the prop is the main or only problem? Will a quick pulsed WOT rev cause damage?:}
Thanks!
Thanks!
