Anyone have experience getting to a 1998 Princecraft Ventura 190 transom?? I am able to expose most it by removing the screwed down/mounted floor pieces (around the port side oil can and starboard compartment) . However, the far edges on each side appear to be wielded down, or part of a much larger fabricated aluminum piece running up each side. I can not find any seems for these pieces. I am wondering if I'll need to cut the edges out in order to expose the entire transom or do I need to keep dismantling the screwed down floor further into the boat in order to expose the transom without cutting aluminum . Thanks for any suggestions
