chrisotenn
- Jun 2, 2010
- 27
hi i have a 84 johnson 70 hp. i pulled the 2 lines off of the solenoid and pushed the key and turned it. it was clicking back there but no gas. so i pump the primer bulb back up and turned the red lever boom gas came out both lines. so i checked i have power to the solenoid and 4 ohms on the purple white wire. so is this bad or not. should i take it apart and clean it check plunger. or replace it. thank you so much
