I'm planning a floor job and really want to get it right. I plan to go the extra mile by installing drainage channels and holes so that any water below deck will ultimately end up at the bilge and keep the under deck dry. I may even install a ventilation system to flow air through those channels. The floor I just removed was completely rotted and the foam was pretty wet on the bottom. The deck appeared to have rotted from the bottom side up. The top of the deck was glassed well. So I guess I'm a bit puzzeled as to how all that water got under the deck to begin with? Is this the result of years of condensation? It seems that rain or water from swimmers would simply lay on top of the deck and evaporate, or flow back to the bilge. I'm just trying to understand the source of this water so I can better eliminate it.
