I had my Merc pre-alpha gearcase resealed about 1 1/2 years ago. But I recently took a close look at the prop shaft oil seal. It is a rubberized seal, but has a visible constricting spring embedded in the rubber material. Most other shaft seals that I have seen, this would be an inner seal and would require a solid oil seal as the final barrier before the thrust washer. I have lost confidence in my mechanic and feel the need to learn some of these tasks myself. Am I paranoid and this seal
is fine? The fluid had a slight opaque look, but not really milky when I drained it.
