Re: pontoon storage
GodsBeast, <br />Re-trailering is just about as easy as getting it off. Back up straight in front of boat. Hook winch to bow, leave vehicle in neutral and wind it under to the front blocks. Ball clasp and safety chains must be good and sound. Might need to go adjust vehicle steering a couple of times. Ive done this several times by myself with no problem. Ground should be fairly level. Styrofoam cubes need to be just tall enough to slip under logs with no problem when boat is trailered and have a large enough foot print to be stable. Just went out and took some measurements. Mine are 24Lx16Wx24H. I think placement is also important; aft cubes are a foot off the stern, fore cubes are nine and a half feet aft of bow. (24 boat) When sliding it off, I begin by tying to the tree, positioning the rear cubes under the rear of the logs as far forward as they will go. Then I pull the truck up 3-4, (winch must be unhooked, or you will need a four wheel drive truck) then snug the blocks up to the back of the trailer. Pull forward another 6, slide the front cubes under, as close to the trailer as possible, pull up another couple, slide the cubes to trailer. Once the front cubes are within 9-10 of the bow, gently drive on out. Individuals with no common sense should not attempt this procedure. Ask at least 3 people who know you fairly well whether you have common sense. I will not be held responsible for any property damage, death or dismemberment.
