Pontoon Corner Caps for 2003 Lowe Suncruiser Trinidad 224.
I'm looking for Corner Caps for the Lowe Pontoon in subject line. The originals are cast aluminum.
Any help would be appreciated.
Thanks,
David
ahicks
For those of us that aren't familiar with the corner caps used on that boat, a picture (and maybe some dimensions) might help come up with something similar.
Lightwin 3
Can't be that hard. They are a 90* cap covering a 90* corner. Every pontoon uses the same thing, or very similar. I think the maker has little to do with it.
ahicks
Might seem so, but when you get into it there are radiused corner caps, with everyone having a different idea of what radius to use, as well as different height/width and made from different materials. There are cast, and there are extruded....
A lot of times you can come up with something that works nicely, but usually they'll need to be replaced in pairs.
With help from this forum, I found some corners for the back corners from pontoonstuff.com.
I'm looking for a front corner like the one in the pic attached.
Thank you so much for your responses!
rbryant1492_mfb
I am looking for the same thing my boat is the 2000 model. I ordered the one for pontoon stuff on 5-5 2018
To rbryant1492
Did it work?
I orderd the LRCC radius corner and it's not tall enough(top to bottom) and it's a lot longer than the original.
