Re: plywood moisture content
Most lumber yards don't have the facilities to properly dry lumber, that takes a kiln if they intend to dry at a rate consistent with high sales volumes. They usually just keep it in a semi controlled environment (covered area) and let it air dry.
A better yard that is charging a premium for dried lumber will sticker the lumber, conduct routine moisture checks and adjust the environment according to the amount of dryness that is recommended as optimal for the particular type and species of wood. They usually don't buy in large quantities nor do they sell that way either. These are your custom wood distributors.
We're talking pressure treated lumber here. Go buy it, find a place to lay it flat and place stickers between it and other sheets. If you're resting spot for this wood is concrete then lay a piece of Tyvex moisture barrier down first, then some 1x2 stickers then a sheet and more 1x2 and the next sheet etc. Turn the sheets once a week.
During the winter months you won't see a huge drop in moisture content unless your storage space is heated. In the mid to late spring, you're biggest change will occur and in the summer when the humidity rises the moisture will return.
My rule of thumb is to buy fresh lumber and note the weight of the wood when I buy it. Its moisture content is highest then and it should be fairly heavy. When it's dry there will be a significant loss of weight which is very noticable. This usually occurs after about a month in mid to late spring like conditions and I usually find that the wood is at about 14-17% moisture and ready to work.
If you want a good meter get a Lignomat.
As a side note: Most all P/T wood contains copper so contact with bare aluminum will create zinc oxide and destroy the aluminum through electrolysis.
The way around it is to use Storm Flash, GAF-ELK or other self adhesive vulcanized flashing in between the wood and the aluminum wherever contact is made and use 18-8 Stainless fastners with a coating of zinc based anti seize compound. That still won't prevent leaching caused by a good soaking on a rainy fishing day so you need to paint your bilges too.
I'll stop for fear of causing a rukus over which type of wood to use. I have Tinny's and I use Exterior Ply and have a couple of low RPM fans/bilge blowers to dry my boat out between uses. That's just what works for me in my climate in Northern California where humidity is rarely a factor.
