Today I bought a Sevylor Fish Hunter HF360 (in Holland, where I live) and would like to try it out tomorrow, but I am totally confused about how to inflate it.
I have (the apparently older ?) model with 2 Boston valves and 3 push-in valves. The manual says to inflate the safety chamber (valve 1) to the "A" marking of the Sevytest and then the main chamber (valve 4) to the "B" marking. But it also said that I have to inflate in the order of the valve numbers, so 1-2-3-4, but nothing is mentioned about the required pressure for the floor and side chambers.
How do I know if the floor and side chambers with the valves 2 and 3 have the correct pressure ?
Thanks in advance for your help.
Ton
Ton
