Please help cant find wiring schematics/diagram for 86 mercury 150 XR2 serial number 0B199676
The lawn ranger
Ive looked for days, beginning to think it doesnt exist, if there is one please point me the way , its the one with the 2 wire reg/rect. Thank you f
boscoe99
What is the issue that you are trying to solve?
The electrical connections to a two wire R/R can't get any simpler.
Chris1956
Crowleymarine has parts diagram for your motor. It might help you to look up your charging system.
Merc went from a simple full wave rectifier charging system, to a single 40A VR and then to twin 20A VRs for their 135 - 150HPV6 motors. My '93 Merc 135HPV6 has the twin 20A VRs. Earlier models have the single 40A VR.
Dukedog
tha only thing with tha one above it doesn't show your regulator.. it mounts directly behind tha flywheel, top of block and has a red and a yellow wire.. they connect to tha rectifier......
The lawn ranger
On the new reg there is 2yellows 2 reds 1grey 1black.. coming from motorside 2yellows 1 red and 1 might be grey
Dukedog
figured that.. tha oem two wire is not readily available except in used on ebay if at all..... we ran 16 amp stuff on everything we had from 150 ta 280's without any kinda regulator without any problems.. we had a very good battery program though....
The lawn ranger
What does yhe grey wire go to? Mine only has 1 red not 2 and mine has 1 either grey or brown or tan color. The only wires that match up is 2 yellows and 1 red that leave the reg with 1 black I assume that bolts to motor and a grey wire and a red wire for nothing hooked to and on motorside 1 light clored wire.. that includes Not using 2 wires from old reg and not using old rect
The lawn ranger
6 wires dont equal 4...so if it dont get easier im screwed
Dukedog
both reds (all reds either come from or go to battery positive no mater they're origin).. make up to any motor red .. one yellow to one motor yellow, repeat with other two.. gray (there is no tan or brown) makes up on motor gray (tach signal wire).. black ground
boscoe99
The tachometer.
The lawn ranger
I wired it yellow to yellow and yellow to yellow and 2 reds to 1 red and grey to the lighter colored one i assume its grey and blck to ground... Whats confusing me is on the diagram it shows 2 yellows to g
The lawn ranger
I giv up stick a fork in me im done, not looking to fix anymore, am looking for some dynamite bout now.
Dukedog
that should work.. don't understand why it would show any yellow ta ground.. on all mercs tha only color goin' ta ground is gonna be black or black/yellow tracer (kill circuit)..........................
The lawn ranger
Stick a fork in me, im done, i am now trying to find some dynamite
Dukedog
you do know that with that type reg. you don't need a rectifier right?.. take tha reg completely off and put tha rectifier only back on it and run it... won't hurt a thing but will see if your problem goes away?
JAN.. we NEVER ran a regulator (justa rectifier) with a 16 amp system and never had any kinda problem...................
