Hi guys,<br />I noticed that I had water coming into the boat thru drive shaft when the boat is in the water only. This problem did not occur when the engine was running on the hose. <br />I pulled the outdrive (Alpha 1) to check the condition of the rubber boot inside gimble housing (drive shaft boot) and found a small crack. After replacing the drive shaft boot and putting it all back together I put the boat on the hose and the water just started flowing into the boat around drive shaft when I started the engine.<br />There were no cracks on any other rubber boots.<br />I have no clue as to what else it could be?<br /><br />Thanks in advance.<br />Lenny
