Re: Picture where water was mixing with the oil
Ya ....if block and head test OK got to be head gasket if that was where the water was actually coming from ???
For sure you had a leak in the pushrod/lifter galley cover (top rear) . That's clear from the picture.
what is a bit strange is that usually water leaks from blown head gaskets are at the front or rear of the engine and not along the sides of the block..
is it possible the engine got soaked in some other way ...like hatch open during a downpour, or hose leak etc ??
when you pulled the head was there water in any of the cylinders ?
