1996, 225EFI Mariner, 350 Hours.<br /><br />Even the dealer has given up and had me call Mercury direct, although they would not give any direct advice which, of course I could understand.<br /><br />Once the engine is warm, over 3000 RPM, overheat alarm goes off, computer retards timing to drop engine back to 3000. If I just let it run, withing 20-30 secs temp drops and engine returns to normal. Go run around the lake at various speeds and will repeat above sequence at any time above 3k. <br /><br />New water pump impellar. New thermostats. New head temp sensor. Healthy telltail. New plugs. Compression normal and equal in all six cyls. I have an infared external thermometer and when the alarm sounds, I pull off the cover and head temps have been around 175-180 after full throttle. The Poppet has been fully rebuilt. Back flushed the engine.<br /><br />The book states that the computer retards the timing when the head hits 200. I am now convinced the engine is not overheating, the computer is reacting at too low a temp. The dealer, to his credit, has tried but now states the next step is to call in a Merc Tech, that the power head will probably have to be pulled to inspect some gasket between the exhaust plate and the head, and maybe replace the ECM for the ignition. He also stated that he has yet to have an ECM go bad on this model engine and that he does not have a "spare" unit in the shop to swap out for testing. I am seeing major dollar signs here. If the exhasut plate gasket was the issue why is the head temp not running high? Do I go ahead and replace the EMC ($650 and non-returnable) or just give it up and let the dealer spend my money until the issue is resolved? ANy ideas where to "borrow" an ECM to test this theory? The dealer also stated there was no way to test my EMC to see if it were malfunctioning. I find that hard to believe. They plug cars into test computers all the time. I am sure this guy is right. He has been very helpful in the past and gives me no reason to mistrust him. He has just run out of ideas as well.<br /><br />You guys are great. Thanks in advance for your help, and I am still ready to send that beer!<br />Chris
