Just Learning
- Jan 28, 2003
- 33
Had the outdrive lube changed (I know I could probably do myself, but its a time thing)before the season and have used the boat twice so far. I've added an ounce or so to the resevoir after each time. After an oil change, is this normal to have to add a little after levels settle after using, or should I suspect a LEAK? Haven't seen any evidence of oil/lube anywhere. If I shouldn't have to virtually ever add lube, and therefore suspect a leak, does this mean I shouldn't take it out again until found (i.e. dangerous to have any leak whatsoever)<br /><br />1997 Sea Ray, 4.3L Merc. Alpha One drive
