Hi All. I posted awhile about the outdrive reservoir<br />losing oil. I had the outdrive pulled and pressure checked before and after replacing the impeller. It <br />passed the pressure test both times. Aftet draining the block and manifolds(350 V8), the water coming out the drain was mixed with oil. I have looked and tried to follow the hose from the reservoir down and I can't get to it. The inside of the boat is black and there are the two hydraulic hoses from the power steering there also. I need a 3 ft. midget to follow the hose. Where and how is the hose connected? I saw the hole/valve on the outside of the gimbal assembly when the mechanic pulled the outdrive. I have looked in my Clymer book and they only show the reservoir. Short of taking it back to the mechanic, can anyone tell me how the hose is connected. Thanks
