- Oct 25, 2011
- 24,992
Re: Orlando Clipper Customization/Restoration
At least enough to not 'see' the grain print thru the spar. Multiple thinner coats is better then a few heavy coats.
It'll probably take at least 4 on the flat surfaces, and every coat you apply to a flat side, coat the edges. That way the edges have twice as much. The end grain on the edges is where you'll have the most movement in the wood during seasonal changes, they will soak up more spar & is the most likely site for water intrusion.
The more coats now, the longer it will be between touch ups & before you'll need to do heavy maintenance.
I'd probably use a maroon 3M pad:
All you need to do is slightly scuff the surface & clean it well so the next coat can adhere really well. The more you sand off, the more coats you'll need to apply, as you're taking mil thickness off as you sand..
2 coats is just a start. If you can still 'see' the grain printing thru the spar, lightly sand & re-apply until you can't.
How many coats should i do then? What grit sandpaper between coats?
