coolguy147
- Jul 14, 2008
- 2,817
Re: Orlando Clipper Customization/Restoration
Transom pad?
Transom pad?
Hello again coolguy. A transom pad is just a small piece of sealed wood some folks put on the outside of the transom, right where the motor mounts to offer a bit of protection and/or to make up some thickness when needed. You don't have to make one, if you don't want to.
The majority of manufacturers install them also, probably for similar reasons and particularly when the transom skin is light gauge.....they can be quite large also depending on the requirement. Plywood was once the material of choice, aluminium plate or polypropylene are far more common these days. Installing one would help unite the transom skin with the core if the seperation is due to distortion.....pics in post #2 and #126 of this thread indicate that a small transom pad has been used previously.
From the looks of it, the wood is just wayyy too thick and causing knee braces to not fit firmly against the bottom of the boat.
Good luck on the essay! Thanks for the update on your project. Before you buy new wood and throw away what you have already done, could you cut/chisel/route channels for the knee braces? You might have recoat any cuts with poly but that's not a big deal or expense.
The thing is though is I still have to get the metal place between the knee brace and wood....
Sorry Coolguy but my old geezer brain is not processing this statement. Need pix or drawing please!
Sorry! I meant metal plate. Between the two knee braces and the wood needs to be a metal plate.
Gotcha! I see what appears to be an "inner skin" in the last picture in post #2. Since I am the Master of the Obvious, if you want it to be like the original design, your new plywood core will have to be exactly the same thickness for everything to fit correctly and allow the fasteners to be installed. You have already gotten away from the OEM design by making it a 20inch high transom and I would question the need for the inner skin. However, I did not see any pictures that tell me if the inner skin is part of the splashwell. Can you show us a picture of what's going on there?
I think it's going to be a new piece of wood because I believe the poly stuff is causing it to space in weird spots and the middle is odd....
