Boomyal
- Aug 16, 2003
- 12,072
Re: Omc tilt problem
The clutch either holds the drive up or it doesn't. If your drive raised 4" and you continue to hear the motor running that would be a different issue. However, if that were the case (where the motor continued to turn with the clutches slipping, the clutch pack would not be able to hold the drive up, in any position.
I would say that you have a drive motor that cannot develop sufficient torque to finish lifting the drive. It takes less torque to move the drive in the first few inches than it does to continue to lift it to the horizontal. Another possibility is that someone installed a cheap aftermarket tilt motor. They are notorious for not developing the proper amount of torque.
