Re: OMC drive fill plug and drain plug>
marunr, what year/ engine do you have? For my '89 4.3L Cobra, the Owner's - Operator's manual states:<br /><br />"Occasionally check the oil level in the vertical drive. Fully thread the dipstick into the hole, then remove it to check the oil level."<br /><br />It also has the following NOTE:<br /><br />"The oil level in the vertical drive must be checked by fully threading the dipstick into the hole. Improper oil level may result in serious vertical drive damage." <br /><br />When refilling the drive it states:<br /><br />"Fill vertical drive with OMC Hi-Vis gearcase lubricant through the oil fill plug location. The vertical drive is properly filled when the oil level appears at the mark on the oil dipstick. Check oil level with the dipstick cap resting on top of the hole." <br /><br />It also has the following NOTE w.r.t. refilling the drive:<br /><br />"When completely changing the lubricant in the vertical drive, the oil level must be checked with dipstick cap resting on top of the hole. Improper oil level may result in serious vertical drive damage." <br /><br />I'm guessing the difference is to put a bit more oil into the drive when completely refilling to accomodate the leakage when replacing the fill plug or the effects of any small air pockets that will eventually make their way to the top when refilling the drive. Also, they may want to make sure noone tries to refill the drive with the dipstick screwed in, which I imagine could lead to some major air pockets. <br /><br />One other thing I forgot to mention is that the drive should be refilled and the level checked with the drive in the down position. <br /><br />yknots, I don't think resting the dipstick in the hole would create an airlock. Although it might slow down the flow out of the drain hole, you'd need to screw the dipstick in to maximize the airlock (minimize the fluid you lose when replacing the fill plug).<br /><br />w.r.t. your other problems, sorry I don't have the experience to be of much help. Like marunr said, if the water intake was blocked by seaweed, wouldn't take the impellar long to self destruct, leading to lack of water getting to the engine. I don't know enough to suggest what problems that might have caused or how to diagnose them....
