AlphaJustin
- Feb 19, 2015
- 53
Hey guys, I've been bouncing back and forth between clymers and the official shop manual and the forums for ideas there have been tons but none are the same as my issue turned out to be so figured I'd mention this.
I rebuilt the outdrive last winter went great got it all done and sealed pressure tested fine used it a couple times no water in the oil fantastic since then I've been having a low rpm overheat issue replaced the upper water pump rechecked and sealed the drive impeller and all clamps to no avail so pulled the drive again.
I found the leak it's at the top of the water uptake tube between the upper and lower unit so out of the water it spits excess water out between the two halves and in the water the impeller sucks more air than water. There's nothing in the manual about it almost like it's unimportant so I breezed over it there's no seals no orings nothing just "make sure they connect" and good to go well it seems it takes more effort than that.
So if your having a low rpm overheat issue and can't find it, hook up the hose and watch to make sure water doesn't leak out from around the anode on the front of the case if it does your drive isn't together right like mine and you need to split it and get the water uptake tube to connect and seal properly.
Hope this helps other people with another thing to check when having this issue good luck all.
