Older Johnson ID needed / troubleshooting ??
Elvis156
Hello all,<br />Seems to be alot of people familiar with how to identify an older 6HP Johnson Sailmaster.<br />I can barely make out numbers but this is what I show:<br /><br />Model: J6SL C08<br />Serial: 100175<br /><br />Can anyone identify year on this particular motor? Also any one familiar with troubleshooting Johnsons? I get no spark on one cylinder- what should I replace first??<br /><br />Thanks all!!<br /><br />Jason
Joe Reeves
Re: Older Johnson ID needed / troubleshooting ??
Your engine is a 1985 6hp Johnson. Trouble shooting.... You'll need to explain what the problem is.
Elvis156
Hi Joe...Thanks for the age info. <br />My problem is...Im not getting spark on one of the two cylinders. Being new to outboards , my natural option is to start replacing parts until I solve the problem. From what Ive gathered so far, There is a small plastic housing that each spark plug wire connects to so no main distributor.<br />From the housing appears to run two sets of small wires to a black box on the other side fo the motor. I I would venture to guess one of these two black housings is responsible for the electric generation for the spark plugs.<br />As one plug gets spark, should I try replacing the housing that the non-firing plug runs to???<br />Also, any good recommendations for a good Johnson outboard book or manual--- I need to read,study,learn,absorb as much info as possible.<br /><br />Thanks Again!!<br /><br />Jason
