Re: Oil Mix for a 66 33hp eveinrude?
Yeah. I did it before several times. I used the upper part of the water jacket over the exhaust as it was easy to get to in one instance. Take the cover(s) off and examine them before you start drilling holes. Some engines have a baffle between the outer cover and the water. If you have a baffle you will have to figure something else.....this will cost you a gasket or glue the old one back in with blue or black RTV.
If water is on the other side, just drill and tap a 1/8 pipe hole and put a 1/8 rt angle/5/16" hose barb in there. Drill a hole on the lower cowling on the drivers side and plumb a 5/16 hose from the barb thru the hole leaving about half inch sticking out. Drill the hole diameter so that the hose is a friction fit so that the hose will stay put when finished.
If that doesn't work I have drilled into the water jacket above #1 cylinder on a 3 cyl Johnny, the same way....didn't look first as I knew water was there....and it worked fine tool
If you make a mistake, you can always plug it with a pipe plug and if the threads are boogered up glue the plug in with metal impregnated expxy.
Good Luck,
Mark
