oil in billage,from black pvc pipe laying in bottom of billage
CableRat
off outboard part{model#983841 seral#T0431044}<br />on dash{boat model 200-br-I/0}<br />tiberias 200bowrider 1987 120hp I/0<br />OMCCOBRA<br />Problem! have a pcv pipe less than 1/2 inch around<br />laying in bottom of billage! end is cut at an angle. comes from underside of engine between where engine and outboard part join togather,what is this plastic pipe for? is it suppose to be hooked to somthing?.it's allowing oil to get into billage water!,and i know thats not right!.Does anyone know what this pipe is called or where it's suppose to be?.Sure could use some help on this one! :eek: <br /> thanks CableRat@msn.com
nightride
Re: oil in billage,from black pvc pipe laying in bottom of billage
it sounds like someone was using that when they drained the oil they would let it run thur the tramsom hole check the bottom oil plug
CableRat
As you can see i am new at this I/O thing,<br />could you tell me where to find this oil plug?,i don't beleive i saw one on the oil pan!<br /> thank you for your help!<br /> CableRat
nightride
You will find the plug towards the back of the tramson put your hand back there it should be on left side facing motor
Jagsare1
First, it's bilge...not billage. Second, simply find the other end of the hose and let us know what it is connected to.
CableRat
Thanks for pointing out the misspelling,however it dosen't help with the {bilage ;) }<br />I would point out the part if i could identify it!<br />but i am unable to find a diagram of this section anywhere on the net,know where i can find them?.<br />Our omc mechanic says it can be any of 5 different things,as listed.<br />1.rear main seal<br />2.valve cover<br />3.oil sending unit<br />4.litter cover on side of block<br />5.oil pan<br />2-3&5 are ok! looking at 1&4 this afternoon.<br /> still,thanks for your input into this matter!<br /><br /> CableRat.
Jagsare1
Cable, if oil is coming out of this hose, it has to be connected to something, right? Follow it to its source. If you can't follow it to it's source then it will be impossible to diagnose here. Good luck.
CableRat
Thanks for your reply,yes i have followed the hose to the end using a light and a hand mirror.so i know where it ends up!.I was not wise enough to think of this the first time!.I just thought if i left this up a little while some other person might find some use for this information!.I am going fishing on the 27th through the29th of this month,then ill take it apart,or if i decide to let our OMC dealer do it.<br />Not sure yet!,hate to miss the fun!.I can run the<br />boat for 3 to 5 hours before i lose a quart of oil. i have rigged a system to catch the oil in a seperate sealed container,with a vent to push out air when oil enters.Will hold 5 quarts,will check often while in use this week.I don't want any oil to get into waterway! or lake! that was my main concern!.Again thanks for your input in this matter.<br /> CableRat
