propbuster
- Feb 10, 2002
- 12
I have a 2001 Glastron with a Chevy 4.3L V-6. Occasionally the engine won't start- especially when I am in the middle of the lake and have turned the motor off and tried to restart. Basically, I turn the key and nothing happens. There is not any noise from the starter or any other component.<br /><br />By the way, I appreciate the kind people who have towed me back to the dock!<br /><br />I have taken the boat into the dealer twice to have them check out the problem. They put it in the tank and run the engine, and restart with no problem, time after time. From what I understand, they can't figure out what is wrong until they get it to not start. It is defintely not the battery.<br /><br />Both myself and the dealer have checked extensively for loose connections or other obvious problems.<br /><br />The problem seems to occur most often in hot weather, but not always. So maybe it is a solenoid, I understand those are sometimes subject to failure when hot. I suppose I could simply replace the solenoid and hope for the best, but I would like to be able to diagnose whether that is the problem. Plus, it could be something unrelated. Maybe it could be the button on the throttle that allows the engine to be revved without engaging the out drive? Or possibly just a loose wire somewhere. Or maybe a key component is getting wet.<br /><br />I am hoping someone else has had a similar problem and figured out how to fix it. This is very frustrating since it only happens on an occasional basis.<br /><br />I would appreciate any helpful advice.
