no spark 40 hp johnson
Ratchet
I changed points on a 62 johnson 40 h p it ran for a few min. then one cyl lost spark, I swaped plugs but same cyl no spark I was wondreing if I could switch coils or test to see if that is the problem?
JB
Re: no spark 40 hp johnson
Yes, Ratchet. You can swap coils, and plug wires.<br /><br />But I think a close check on the new points would find your trouble.<br /><br />Good luck. :)
Ratchet
should all three wires(condensor,coil and black wire from harness)go to screw on points? I'm assuming so, cause other side works.
