No down trim on '02 Suzuki 140 HP
Gevans17
I have "UP" but no "DOWN" trim on 2002 Suzuki 140HP 4 stoke. "Up" trim works from both trim switches, so I assume switches are good and I have a relay or a wiring problem.
Does anyone know where to look for the tilt/trim relay on this engine?
bezerk
Re: No down trim on '02 Suzuki 140 HP
port side behind the square plastic cover .should be two one with a blue lead one with green, if the down is not working replace the one with the blue wire .has to do with the way suzuki changes grounds.
Gevans17
Thanks..is it 2 separate relays, or are both up and down together a 1 part?
Gevans17
Are you sure about that? Every other post I have read says Blue is Up/ Green is down.
lakensea
Buy a manual so you can properly diagnose the problem. Both relays need to be working correctly to complete the circuits.
bezerk
yes blue is up,green is down. i want you to replace the up.
Gevans17
I would buy 1 if I could find 1.....Cant find a Suzuki 2002 140 HP 4 stroke manual anywhere
lakensea
Have you tried going into your local Suzuki dealer and asking if he would order one for you?
MichaelP
I have a 2001 Suzuki 40 hp 4 stroke with the same problem. Intermittant down tilt. Up tilt works fine. Is this fix the same on mine? When I hold the trim down button it makes a arching sound.
