I have read many threads explaining proper materials and basic technique for replacing plywood transon on a jon boat.
I cannot find an answer to the question: Can I use several pieces instead of one solid piece in order to avoid cutting and/or bending so much of the metal framing for the transom? I realize I must remove the support bracket and somehow get access to either the top or bottom lip to slide in any size replacment, but it would be much easier if I could use two pieces cut either horizontally ir vertically.
