Re: new honda 90hp what is a safe rpm
The power band on that outboard is fairly broad. You want to be propped WOT as close as you can to 5800 RPM's- which is the RPM where it produces its peak HP. You can prop WOT up to 6300 RPM's, but to get the most benefit, target your WOT RPM at 5800 in your prop selection. Obviously, prop tune for normal payload, fuel load, passenger load, etc.
Every boat is different, but I suspect that if your "seat of the pants" feel for the sweet spot is 5000 RPM's, then it could be fairly accurate (I would think the sweet spot would be more around 4500- but that obviously depends upon the boat you are running, and how you are using the outboard).
