McVee1
- Jul 2, 2009
- 11
Hello, I am new to the forum, and am also a new boat owner. Two weeks ago, I purchased a 2006 Sea Ray 200 Select. It came already equipped with 12 speakers and 2 500 watt amps all of which draw power from the start battery. I am wanting to install a second battery to run the stereo alone because I like to leave it playing while swimming. I'm not certain, but believe that the boat alternator will not charge both batteries if connected in series. Please keep in mind that I am not at all electrically inclilned.
What type of battery do I need, and how big does it need to be?
Is there some sort of onboard charger that I can install that will keep the second battery charged? Or, if the boat alternator is sufficient enough to charge both, is there some kind of switch or disconnect that I can install between the batteries so the start battery will not get drained by the stereo while the engine is off?
Also, I am looking for a cleaner for the seats that will remove scuff marks, mold, etc.
Thanks
Thanks
