Trihull&error
- Aug 4, 2013
- 14
I got a hell of a deal on a 1972 Forester for a 1st boat. and want to know if it is set up properly, I put a couple small dings in the prop nothing that needs replacement but a back up or better prop would not hurt.
Boat is a 72 forester tri hill fiberglass 750lbs dry
Engine is a 1979 85HP Johnson V4 79txl85
running a stainless steal 13 1/4 17 pitch
plate is set even with the keel
Iboats specs this boat as follows
This outboard runabout is 15.08 feet long and weighs 750 (pounds dry). This weight does not account for passengers, fuel, or gear. The beam of this craft is 72 inches
acceleration is quick tops out at 35mph on the GPS I figure this is about a 20% slip is this normal or am I running the wrong prop?
The boat does not have a tach.
