chartersj
- May 14, 2013
- 281
Just purchased a boat with a 5.7 efi. After it warms up the idle goes up around 1100 rpm and I believe it should be around 650. The throttle cable is not holding it there, I can see the lever all the way back to the non adjustable stopper. Even removed the cable to be sure.
Any insight to what to look at next?
I should add it smells like it’s running a little rich and had some soot on the transom after a 20 minute run. And doesn’t start up instantly when cold. Will start and die a couple times before it will stay running but that could be from last years gas still in it.
It has roughly 100 hours on the block due to bad winterize
