need more speed /20hp outboard
andrew k
i've been racing small engines for a couple years now. i have a 20hp merc. my boat is flat bottom that weighs about 100lbs. its running about 42mph. i've already tweaked the read valves drilled the exhaust upgraded to a 25 carb. just need a bit more to get by the compitition, any suggestions?
Re: need more speed /20hp outboard
You're Probably going to get More,+ Better responces if you post this Question up in the Mercury Outboard forum........
JB
Duplicate. See Merc troubles.<br /><br />(241)
