Hi, I recently put a long shaft 28 horse Evinrude on my 1968 13ft boston whaler. It is manual tilt on it and set up for cable steering. After reading alot of the post on the board I added a jackplate to raise the vent plate to about even with the bottom of the boat (The measurement on the boat is about 17.5 inches, the motor is actually 21 inches to vent plate). <br /><br />The Problem I have with the boat is it planes out pretty slow( i would say 8-10 sec) and throws dual rooster tails about 20 ft behind the boat after it planes. It also seems to drag a little. The boat also comes out of plain pretty fast if I get below 3/4 throttle.<br /><br />The boat weight was pretty heavy in the back and I am not the smallest man on the lake, so I tried relocating the weight up front to see if it helped, If it did it was not by much.<br /><br />My knowlege is pretty limited and all I have to refer to is the short shaft suzuki 30 hp that was on it before. It was a short shaft, and it too planed slow but did not drag or throw up the large tails. The short shaft vent plate sat about 2 inches above the boat bottom. <br /><br />I am thinking the motor is sitting to low in the water but wanted some opinions as to should Raise it more and to what good or bad effect this will have on the motor.
