Need a Owners Manual (or copy) for 96 112 Johnson
fone_man
Re: Need a Owners Manual (or copy) for 96 112 Johnson
The Model Number please......<br />The Model ID number is essential for us to ID your engine, see below to locate:<br /><br />For Johnson and Evinrude outboards, check the following locations: <br /><br />-the stern mounting bracket <br />-the freeze plug <br />-the flywheel <br />-the side of the cylinder assembly <br /><br />For OMC Stern Drives: <br /><br />-the nameplate attached to the rocker cover <br />-the front and/or the rear of block, behind or in front of port cylinder head <br />-rear of block, port side, below manifold <br />-the starboard side, above the starter motor <br /><br />Hope this helps.........<br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man <br /><br /> :cool:
dougay
The model is j112tslsledr.<br /><br />Thanks
fone_man
Check serial again.... never heard of 112 HP???<br /><br />Nothing matches the way you have it??????? :confused:
dougay
Sorry about that. I had an extra "S". Here it is again: J112TSLEDR. It's listed on OMC as a 122 hp V4 without oil injection.<br />Thanks :D
fone_man
You know more than I do....... NEVER HAVE HEARD OF 122 HP....<br /><br />Check serial again.... never heard of 122 HP???<br /><br />Nothing matches the way you have it??????? <br /><br />115 or 120 or 125 or 130 or 135... everything in HP range runs on a 5 HP up & down...<br /><br />I cannot help... but have never heard of such a monster... GOOD LUCK!!!<br /><br />fone_man
clanton
Its a 1996 90 degree 112 hp special long shaft with tilt&trim. Dont what the R is for maby rope start.
fone_man
Man...... you threw a "wierd" one!!!!!! Finally found a 112 HP listed in 94-95...<br /><br />R is Model Run<br /><br />TS is still throwing me off<br /><br />L = 20'<br /><br />ED =96<br /><br />Just when you thought it was easy... Bingo!!!!!!<br /><br />Please someone throw me a bone... it has got to be easier than this... gone to bed!!!!!!<br /><br /> :mad:
fone_man
Ken Cook Co... provides older manuals/service/etc on J/E/gales.... since the change of guard @ OMC... check with them on who handles the newer stuff... the best I can do... My info is limited on what you have but I hope this will direct you down the path a little further...<br /><br /> :confused:
