BOATINGmatt
- Sep 28, 2009
- 93
I have a 20 ' wellcraft outboard that has two drains in the motor well where sea water enters and then leaves...One of the drain holes has a plastic insert and does not leak into the bildge...The other hole has no insert and after much looking around i have discovered that sea water in migrating through the fiberglass and plywood core in the trasom that is exposed in the drain hole..the water is a steady trickle into the bildge..Where do i get an insert for the drain hole and what is it called..also how do i put in in and seal it in a wet application..the boat is at a mooring and id rather not pull it untill the season ends..(dont have a trailer)..( I can fix better when its on dry dock but what can I do for now)...thank you so much
matt
matt
