Hi, I recently took out my grandfathers 1972 40hp evinrude and got it running. It seems to be a fine motor, changed lube, water pump, spark plugs and cleaned carbs. I cleaned and set the points. <br /><br />The thing starts like nothing i have ever seen, it never fails to start at about 1/4 the pull of the rope. It idols great and has lots of power.<br /><br />The problem I have it is rattles so much, that it drops parts in the lake, so far I have had the bendex bolt on the starter, 4 of the water jacket bolts, the lower starter bolts that hold the thing together, the carbs almost fell off,@ starter mounting bracket bolt, and 2 times the plugs have almost rattled off.<br /><br />Did these motors rattle like this or is something wrong?
