Re: More Power!
Here's what im after I have a omc 190 (ford 302) and I would like a little more power, but more than any thing I want more reliablity out of it. It doesnt get good fuel economy with the 2barrel holly. Would love to get rid of the points it that helps. The wifey will be running this boat by herself sometimes so reliablity is key.
I'd certainly concentrate on getting your outdrive to stay together before you go thinking about HP. I think you said your boat was 22 ft. That is a lot of boat for the 302. It's going to be under constant load pushing that scow and going to use a lot of fuel doing it.
A 190 hp 302 w/2bbl in an 18-20 ft boat is a much better combo and about as economical to run as any motor with any poop to move them along.
If you went to a 4bbl, you might get a bit more power but you will be into the secondaries all the time and just suck that fuel down.
I can run my 5.0/302 4 bbl, in my midweight 20 footer and get as good a fuel mileage as I got with the two barrel AS LONG AS I keep a light hand on the throttle. When I really want to make it scoot, I pay the price.
You'd probably do better with a 351w with a 600 cfm 4bbl. You probably will not get any better mileage but you will have more torque to keep the motor from running so hard. But if you are running an electric shift OMC, I wouldn't go there either.
