JetSled
- Apr 18, 2009
- 22
I have an opportunity to repair my boat in an aluminum welding shop to repair the hooking and dents on the bottom of the hull.
It has seen 20 years of use and has always had issues of gulping air in choppy water... leading to cavitation. By use, I mean jetting rivers... usually moving into shallow water on every trip.
I would like to get recommendations from those of you with experience.. hoping you can provide suggestions on what would be possible, feasible, desirable on this hull.
The shop where work will be performed is experienced in aluminum welding, not boat hulls. They have the equipment necessary to rotate my boat upside down and perform all welding necessary. It will only cost me materials and a fishing trip!
This was a custom made 1980's flat bottom, on which the original builder added a hollow center section, presumably to soften the ride or absorb the dents..? May have been added to divert air away from jet intake?
The softball sized dents may be repaired.. but I primarily want to focus on getting the centerline/bottom straight.. and improve the flow of water into the intake.
Let me know if you need more info or pics...
Here are some pictures:
The intake grate has been removed... I'll find a picture the grate installed.
