Hello, and thanks for reading!
I have a Minn Kota Riptide ST 55# thrust, that I have used for just one season.
I need to check behind the propellor for fishing line. I removed the anode and bolt that is on the outside of the prop, but the prop still doesn't want to come off. I talked with my mechanic, and he sais it should come off once that bolt / anode is removed. He suggested spraying some WD-40 in there to see if it helps get things moving. Any other suggestions for how to get that prop off? Am I missing something?
Thanks again!
Thanks again!
