URBANHILLBILLIE
- Mar 1, 2005
- 13
Hi, I have a 1976 115hp johnson seahorse outboard.Would it help to use midgrade instead of regular gas to improve performance? THANKS FRANK
Very well said. DITTO!!!OMC engineers designed the motors to run on 87 octane and Champion plugs. It's not a matter of "better" plugs or gas, it's a matter of what's better for the outboard motor as designed. Run fresh 87 octane gas and Champion plugs in your OMC's. Run whatever the Merc experts say to use in your Merc's. Those old boys with the slide rules and pocket protectors and "high water" pants that designed the Merc and OMC motors were GOOD. Follow the designers' specs and your outboard will live forever and perform beautfully. Deviate from the factory specs only if you are a bonifide outboard performance specialist out to win the race and longevity be damned.<br />
