Purchased a new '08 Mercury 8hp 4-stroke trolling motor. Model #ME8ELH. My Garelick motor bracket recommends to remove the motor while trailering. So I want to install a quick disconnect plug between the motor and battery rather then unbolting it from the battery on every fishing trip in the dark.
Would anyone happen to know the wire size of the factory wire that goes from the battery to the solenoid, so I know which size of pins to order with the connector? Wasn't sure if I should put this in the electrical or Mercury section. But this could be Mercury specific, and hopefully a Mercury mechanic remembers the size. THANKS
