mercury 75 4 stroke gear lube
garm
changed gear lube used mercury high performance after doing this then i realized it said not to mix with premium gear lube i did let it run a few minutes should i change it again and put the preminum back how would i get all the high performance out
Laddies
Banned
Re: mercury 75 4 stroke gear lube
No it will be fine, you are not to mix or add the two oils together but draining and refilling with the other is OK
