Hi thanks for your replys im not sure if its all the seals or just the prop berring seal attached is picks of the water surface after running the motor.
is it the hole prop shaft that comes out or is it the prop and the berring carrie as one unit including the cercle peice with the 3 legs witch link to the berring carrie, when i look right down inside the unit i can see what looks like a key way does this need to be removed.
what is the LU
thanks
As Merc850 already said; you are better of at this point to shop for another LU (lower-unit) because of the chunk missing
there's a lot of corrosion built-up and I have my doubts if the surface still can be re-finish/polished smooth for the O-ring to seal
Normally after the retaining-ring (aluminum or plastic) is removed the entire Bearing-carrier incl. the prop-shaft can be pulled out.
as Racerone said, the key will just slide out with it (don't loose it)
Did you pressurize the LU to see where it is leaking?
