Mercruiser, 7.4L MPI. I will get the engine number tomorrow but it is the kind with the thermostat in the heat exchanger, I think they only did that for a couple of years if that helps. Freshwater cooled, damper pulley mounted raw water pump.
I can start the engine up and let it run all day at the dock and idle up the creek with no problem. When I get out on the water and do full throttle it will get hot after running for about 5 minutes or so. However, it really starts to overheat after I pull it down to idle from this full throttle.
Things I have done so far: Changed the raw water pump (housing as well), changed the thermostat, replaced manifolds and risers (for another issue), drilled open the holes in the intake screen, found and fixed a few antifreeze leaks.
The next thing I am going to do is to take off the heat exchanger and the oil cooler and boil them. I just thought I would post this to see what anyone else thinks.
